Side Marker Lights - Front & Rear
Bowling Green, KY
Was looking to buy all new side marker lights for my 40. The rears are still readily available but the fronts are not through Toyota.
What I am wondering is if the front and rear side marker lights are exactly the same size?
Does anybody know?
You can still buy all of the parts through Toyota but the amber front lens. I just replaced the rubber and trim ring on my 40. The bulb housing is the same as the rear the only difference is the angled rubber grommet and the amber lens. I got a used amber lens and buffed the scratches out and it looks good as new.
Alex, I don't know if I was clear in my post but you can still get the angled rubber grommet for the front light from Toyota. Everything else is interchangeable with the rear lights. I personally don't like the CCOT repro lens is it is different than the OEM lens. The lens are on ebay quite often and you can get them from 40 sites that deal in used OEM parts. I ordered my lens from
FJ40 & FJ45 Parts Landcruiser Parts. I called and they shipped them out to me I believe for $25 for two amber lens. If your current lens aren't cracked they can be buffed out quite easly.
Sorry to get OT - but on these sidemarkers is the only difference in years the plug? I have a 1970 and the price difference is $14/side ($28 total.) If it is as simple as cutting off the plug, soldering the power wire to power, and grounding the other side, I'd rather save $28 and do it that way. Anyone? Or are my way off?
Jonny
Jonny
The only difference is the plugs. The years are listed below with the different types of plug. Go with the cheaper one and adapt it for your use. I hope that this helps. You can get these parts OEM straight from Toyota. You can get the total assembaly or just the individual parts that you need. I would place the bullet connector on it for easy removal instead of soldering wires directly.
Awesome man, thank you :cheers: I just ordered the 78's from Toyota for $20/side. OEM :D
Jonny
Where did you get em? online?
I deal with the parts manager at Champion Toyota in Houston. This is what I ordered and the prices for comparison. Everything is for a 1970 model 40 aside from the sidemarkers.
53506-60010 $26.28 each (Hood Hooks)
75305-60011 $26.28 each ("Toyota Landcruiser" emblems on front fenders.)
53334-60030 $18.87 each (Windshield rubber bump stops)
81750-60031 (1978 + drivers rear sidemarker)
81760-60021 (1978 + pass side rear sidemarker)
The 1970-1977 rear sidemarkers are:
81750-60030 $30.26 (drivers)
81760-60020 $30.26 (passenger)
Hope this helps.
Jonny
:steer:
I am a newbie,so please be gentle. Front amber lights are oem from ccot I bought them for my 71 frame off build.
There is nothing wrong with the CCOT lights except the price!
The lens is a little different, but workable. I'll bet they found some lenses to slap on their rear lights and markup the price 100%.
BTW, you know your post is useless without pictures!
Sor has some also...about $10 cheaper each
Thread resurrection...
Ok, so I am rebuilding a set of '69 fenders to go on my '78. The lenses on the 69 marker lights are good, but I need to replace the angled gasket and would like a new housing and wires.
If I understand the above, I should be able to order a rear housing, a trim ring and the wedge gaskets all new from Toyota and then swap my lenses into them to complete the unit, correct?
Would the 81750-60030 and 81760-60020 be what I am after as far as the housing and trim, replace red with my amber lenses?
And does anyone know the PN for the angled gaskets?
Thanks,
MT
