I wonder if 2016+ 200s with the 8-speed experience this shudder/hesitation?
Very strange but I ran premium fuel the last tankful and the occasional shudder at low revs/ between 50-70mph has almost completely disappeared.
Could it be bad spark plugs ?
Run some bg 44 k or red Line (60103) Complete SI-1 Fuel System Cleaner Gas and Injector Additive Treatment-15 oz Bottle
Make sure u are top tier gasoline.
How about fuel with 10% ethanol in California? Could be the cause? Any kind of fuel additive recommended?More likely the non-premium gas you were running before was just bad gas - or maybe just marginal.
This is somewhat telling and the symptoms you're experiencing is not normal. There's something going on within one or multiple combustion chambers related pre-ignition/knock, that higher octane fuel is helping with. A scanner or techstream may be able to help localize which cylinders this is.
As for the cause, can be multiple things. Yes, could be as simple as spark plugs and would be something to try. Could also be an injector, deposits, or defect/degradation/damage within the cylinder causing hotspots that cause pre-ignition.
I'd have them do a major tune-up including combustion and EFI cleaning service. New plugs. And then give it an Italian tune-up.
If it's under warranty, be firm and insist this is not normal. Let them figure out how to fix it.
I think you do if it's documented.My warranty has expired but I reported it when it was under warranty. They chose not to look at it.
I think I have a leg to stand on if it’s documented.
I think the next step is a transmission fluid change at the next service - it is recommended in my manual at 50k miles, and I am at 46k.
I have no such recommendation in my manual. Are you sure?
Yes 100%. I am based in the Gulf and perhaps have a different manual to the US.
Yes, I believe it is the AB60F gearboxOut of curiosity, do you have the 6-speed automatic?
