I have to decide if I am going to put my old birfield and axle shaft back in or not. The axle housing is bent!
Time for a C&T on my spare axle and I may as well put the ram assist on at the same time.
Here is a link that talks about mounting a ram.
https://forum.ih8mud.com/hardcore-corner/349026-hydro-assist-ram-mounting.html
The hydraulic ram gets its fluid flow from the steering gear box that has been drilled and tapped. The ram aids steering by applying additional pressure to the steering tie rod.
I will be working on my front axle this weekend so I won't make it to the trail run. I figure that if I tear down my axle it will snow so I am trying to help you guys out.
I ordered knuckle rebuild kit and axle gussets from Marlin and spring perches from Ruff Stuff.
