Show me your project.
And onto phase 2.
I managed to source a BJ42 chassis and got it towed to me, 1400 kays away.
It had some rust in the rear of the chassis, a 5 speed and a 400,000 kilometre old 3B.
So I proceeded to fix the rust, source all new hardware, new body mounts and started to put it back together when my friend pointed me towards a rebuilt 3B with AXT turbo kit on it.
So I bought that too.
I have repaired the old BJ wiring loom and put everything back together with the best of my ability and resources available to me.
Here's a few pictures of what I've done over the last 7 weeks.
I'm probably still 2 weeks away from it being drivable.
So once this is completed, it will be on to phase 3 of the build which will hopefully be the final chapter (aside from regular maintenance and upgrades; lockers, intercoolers, 35s etc) which will be the body.
This car has zero rust but it is also a patchwork of repairs not done particularly well.
Ideally, I'd like to find a good tub and repair it, put nice shiny paint on it and make it as stunning as I can but I think the more probably outcome for me will be smoothing out the existing body and then hitting it with a Durabak/Rhino liner type product.
I'll also be adding a set of SOR roll bar pads and a bikini top shortly as its starting to get a bit sunny up here in the sub-tropics.
This is what I started with. Looks fairly good but under all the diamond plate was tons of rust. Under the hood was a mishmash of parts, including wood screws holding the battery tray down, incorrect parts , blown head gasket and other things to numerous to mention. The 40 was almost impossible to start and once started the brakes were so pitiful I though that I would never stop. So I embarked on a 1 year build. Originally it was a soft top model.
So, had the head rebuilt with hardened intake valve seats, replaced the carb, water pump, installed a correct alternator, new radiator, hoses, kept the original dist, but had it checked thoroughly, installed an electronic module and new coil, installed disc brakes on all corners, replaced the old 3 speed with a newer 4 speed, new clutch, pressure plate and bearings, had the drive shaft lengths altered and had new universal joints installed, took it to a hot rod shop and let them install the new sheet metal parts I purchased to rid it of all the body rust and then they painted it. For the past two weeks I have been reinstalling all the parts I removed and installing the new parts I purchased and stored. I have a new top to go on next week which should complete the major work. I wanted to do a frame off restoration but the frame looks to be in good shape. Power steering will be added next year along with a new steering column and steering wheel.
Here is what I have now.
Had my first real drive even though it was raining.
My 1971 FST. My brother bought it new and it's been in his barn for 20 years. Now it's mine and I use it. Restoration will start this winter
I already did the seats. They were shot
