Show me your 31 inch tires
Here's mine. 2.5" lift. Sorry, that's the only picture I have showing the tires.
Here's a few shots of mine. 4" HFS lift plus 2" shackles (on right) with 31x10.50.15 Cooper Discoverer ST's. Not crazy about the shackles, love the tires.
These are 31x10.5x15s, BFG ATs on MT Classic IIs.
Lift is a 2.5 HC with 1.5" extended shackles in rear.
Hey Fast Eddy and phrogg4evr, how do you guys like those 31x9.5 Swamper TSL Radials?
I love the "look", and imagine they would go really well off the black top, but I heard/read that they can throw of chunks rubber off if used as DD, or on the highway...is this true?
Edit: These would make a great choice after the 700x15 stock tires..basically same height, but just a little wider...that is if they ride well as a mild DD.
Here's mine. 31x10.5's on 15x10 rims. I am about to put these tires on some factory FJ rims after they are blasted and painted. The only lift I have is 3" over stock shackles.
attachment.php
OLD pic...
Goodyear 31 x 10.50 Wranglers and some loooong shackles.
31-105015 BFG A/T's and Black rock Alum wheels
Hadn't thrown any chunks on them, but they are a pretty soft tire and will wear fast in DD street and highway driving:meh:
They do look kewl though, has the old tractor tire look:grinpimp:
I'm not too worried about the wear, more concerned with wandering, braking, water, and general road/offroad handling for an older 40 with limited usage.
Consider those military tires, they look cool also, but most would not use them if they had a choice...hope these do not fall into that category...
I have put about 1500 miles on mine so far, some on and some off road. Braking was fine, was fine on wet roads, as far as wandering, the only wandering my truck does is when I forget to tighten something down. They are a great tire, but based on the feedback I have seen they just will wear down in 15k~ish if you drive it exclusively on road
They do make a cool noise when you lock them up;)
