Should I use thread tape on this fitting?
Gardnerville, NV
Website
www.billetriflesystems.com
Thoughts on using thread tape on this fitting that runs to the heater valve?
Rig is 77’ FJ40
Can’t hurt I would think. The only time I would not use Teflon tap is on things like water temp sending unit
Teflon thread is not my first choice if threads are in good condition. I use a paste available at any good hardware store that comes in a white tube or a yellow tube. The yellow tube is for all types is gas, liquid or natural/propane, hydraulic fluids and other type products. The white tube is water, ect. I would use yellow in your situation. Good luck.
Threads are in great condition.
You just reminded me that I have some of this type of sealant in the “House” toolbox... think this would work?
That's it. Should work for your application without any issues.
The main reason I use the paste is the tape can cause the female part of the connection to crack if too much torque is applied since the tape increases the diameter of the male fitting. My aviation training tends to creep in to my other job applications and has never caused any problems. Good Luck
