Should I go lower?
Bellville, TX
Currently running 850/860 combo and in my mind, the rig looks perfect. After installing the springs, I bought some OME 2* CC Bushings from Slee and had them pressed on here in Houston. (Local shop charged me $350!!! :mad:)
Anyway, dumb*ss me didn't get the caster measurements before I got the bushings installed. I took the truck over AFTER they were pressed in, had a Firestone shop set the toe and give me all the other readings...
Friggin caster is still .2* left and -.3* right.
I even, on Christo's great advice, took the cruiser to another alignment shop to verify that the readings are right...and they are. You can actually feel the looseness in the steering, esp. on a windy day or pulling a dirtbike trailer.
So, million dollar question is...go lower cheaply with new 861/862 setup, thus giving more caster, or trying to fix the caster with plates, and pressing the old bushings back in to the tune of another $350. It would really be an easy answer for me if I knew of a Houston shop that would do the job cheaper..
ON A SIDE NOTE, Slee has been patiently working with me through this really minor thing (in the whole scheme of things). Christo has even taken my hub to flare measurements and compared them to rigs in his shop and given loads of advice. AWESOME SERVICE! They are truly top notch. :beer:
This is what I did: I bought some arms cheap at the salvage yard and went with plates. It drives great with J's. I haven't had either truck measured. I then sold the old arms with the caster bushings to recover some $$$. You will not want to go lower.
Are you sure the bushings are properly installed, doesn't sound like it? $350, I would find a new shop.
X2...sounds like your shop did not follow the instructions provided with the bushings.
Which shop did you goto? Sounds like they milked you....
Landtank or Slee plates are much better than any bushings.
So you have J springs and CC bushings? Caster sounds about right.
Put rubber bushings back in and do caster plates. I pay the local shop guys $20 and the shop is good enough to just put it straight into the tech's pocket.
Call around and make sure you pull the arms yourself. If you are having the shop pull and reinstall the arms, it is gonna cost you some coin no matter what.
Thanks fellas, for all of the input. I, too, think that I prob. don't want to go lower.
I think that I would bag the CC bushings and do the plates if:
1) I could find a shop to press in stock bushings cheaply, and
2) I was convinced that there isn't anything goofy going on with my front end to not let it rotate to correct caster.
I do have a little bit of grrr in the driveline, but not until I get upwards of the speed limit. ;)
I'm actually thinking about pulling the arms and fedex'ing them to Slee to let the masters figure it out. :cheers:
If I remember correctly (its been a couple of years) you need to mark the arms BEFORE you start, with the truck on a level floor. I wonder if the shop put the rear coils in before they started to work on the front...fresh rear coils would prolly rotate the arms enough that it would screw up the process...just a thought.
Thanks again for the advice.
The shop threw away my OEM bushings.
I'm gonna order some 861's for the front and see what the caster measurement turns out to be. I wonder how bad the stinkbug will be, too.
If later in a few weeks I find a little more money, I'll prob. order new stock bushings and the Slee plates...just can't do it now.
I wonder do you need a double cardan up front when you use Slee's plates? Maybe that is just with Landtanks. I cannot recall.
That is what is weird. He does not have J springs and from photo's it appears the bushings are correct. Front up and rear down. Hub to flare measurements are about 2.5" of lift. Never seen a truck this low on caster.
Interesting - he needs to find a better shop, but sounds like the blue bushings are the answer.
