shocks !?
Kansas!
finally got around to the rear end of my 68 fj40 tonight....started wd40 on shock bolts getting ready to remove....i notice a little silver sticker at the bottom of the shock...low and behold it says man-a-fre....these shocks are different so i go to their site and can find nothing....can someone tell me what they might be they have what appears to be coil springs around them.....that extent all the way to the top but do not make it all the way to the bottom. why would you use them? are they still made? and should i replace them with like shocks? will the coils come off and reinstall over the new shocks i have already purchased? thanks in advance for the help.
osagecruiser :)
Had something similar to what you ar talking about on the rear of my truck when I purchased it in 1988.
Pitch them, and install a quality heavy-duty shock.
Good luck!
-Steve
those are an overload shock...if you think your ride is still, that's the reason....
ditch and replace completely....that is OLD school stuff there....
They are a lot of PO's bandaid for the rear saging on cruiser. They will lift it a bit in the back. If you take them off and don't like the height you can get the springs from AZ, but recomend removing them.
tonka
i am still trying to sort out the work of this PO. v8 conversion nicely done..frame is spotless..cant figure out suspension it appears to have plenty of hieght, we wont run very wide tires...no power steering and none planned. body is excellent only bad rear sill. i will mount the new rear shocks and see what happens. thanks for your input!
osagecruiser
Steve, correct me if I'm wrong, but those were generally a quick fix for sagging
springs. Problem is, they caused the shock mounts to take the brunt of the initial compression, before the sagging leafs took over. Shock mounts are not designed to take that kind of load, ie shock pins at right angles to the load.
Osage, sorry you bought new shocks as I have a set of near-news for my usualy price. Eh.
Ed
thanks guys for the additional info....my connection to cheif wahoo...born in ohio indians fan when if you bought 8 gallons of fuel at a clark gas station you got 5 free tickets at the beutiful lake front stadium...go tribe!..thanks steve @ man-a-fre.
ED
i probably should email you prior to all new parts purcahses.....2.5 lift springs???
bought the shocks could not afford the springs...yet.
thanks again
osagecruiser
springs.
Ed
I guess so, they said they did a lot of things. It's like adding 10 extra leafs to the pack. It will fix your sagging problem, but ride like the spring is welded to the frame. Wouldnt be my first choice in shock options.
osagecruiser, your welcome. I dont think I helped you out much but let me know if you need anything else. I knew putting our name on the bottom of those would come back to haunt us. :eek:
Steve
steve...not to haunt you.... i was convinced that whoever the PO was they had no idea where to get or what to get as far a s parts go for this rig......i was really kinda happy to find your sticker on there. i have no idea who the PO was but at least he tried to stay with good parts.
osagecruiser :cool:
