shocks
The factory has more than one specification for the shocks, depending on year model/equipment.
The aftermarket often does not get that precise. They pick one somewhere in the range and call it good.
i see some fjz shocks in the for sale section is the reason im asking, they look like a really good deal dan do you think these would work? thanks
I believe that OME lists one part number for all years (depending on which type of OME shock you select). If that is accurate it stands to reason that you could use later factory shocks on an earlier vehicle. I would use them in sets if you go that route so that the valving is consistant within the set.
