Shocks/Lift Dilemma
ABQ, NM - NE Heights
Ok, so here is the dilemma. I have a 96 FZJ80 with 175K miles on it. I know I need shocks, and I am pretty much assuming I need springs, too since neither have been replaced at least since I have owned it for the past 50K miles. Recently I got new tires all around, the BFG AT 285/75/R16 sort of figuring that I might soon get a 2 1/2" lift kit from Slee.
With the larger tires than I was running at stock, is it wisest to go with the 2 1/2" lift kit or can I just replace my shocks stock size and be fine with that? The way I figure it if I also do springs, is that from Slee, it is $100 more to go 2 1/2" anyways so well worth it if I also do springs.
The dilemma part comes in when I think of the miles I have on my truck. I know I'll probably not get even close to any $ back from installing the lift kit, if I decide to sell it....so should I just replace the shocks at stock size or should I just go all out and do the 2 1/2" lift kit installation including the springs and spend more money than if I were to just replace the shocks all around (in case I sell it within the year).
If you don't plan on wheeling it, I would just replace the shocks with stockers from Dan. The stock LC shocks are great quality, well matched to the truck and ~$100 for the set.
Never install anything based on some sort of return on your investment. Install mods because you want/need them.
FWIW there are many threads on running 285/75s on a stock suspension, and it's fine. I ran 295/75s on my truck for a few months before getting my lift - I even wheeled it - and had no problems.
Thanks for the input thus far.
Well, I wouldn't say I do a ton of offroading, but I do get off the beaten path to some remote camping spots several times a year. The thing too, is that when I am loaded up with just one extra person and our camping stuff the rear sags quite more than I like - thus leading me to believe that I should also replace springs. If I do springs, why not just do the 2 1/2" lift kit from Slee, ya know.
I am not thinking of the lift as something I'll put into it and think I'll get it back money-wise if I sell later on. It is more of a dilemma considering all the other things, if I do decide to sell later on this year for something newer and with less miles, I would have put that extra money into this truck instead of being able to put it into the cost of something newer down the road. LOL.
If its mainly to get into the backcountry without rockcrawling---id go with the OME low lift and stock shocks from CDAN. Cheapest route and it will get you a good 1.5"of lift over soggy old springs. The low lift heavy duty springs have much better control of the vehicles weight if weighted down for camping/backcountry.
With the larger wheels and the low lift springs--you will likely end up with 2.5"+ over stock height when all is said and done.
Shocks from Cdan- $125
Springs from slee- $300 set of 4.
Go the "Fit your needs" route and save $$ for a diesel Toyota coming in 2009/2010.
if it helps you can follow my link to see my 96 with Emu 'stock' coils, Toyota shocks and 285s. If you did a 2.5 lift you may want tires soon because they won't fill the wheel wells, you'd probably want 305 or 315s. But you said you just got new BFGs, so you're good on tires for a few years.
Toyota coils would work fine, but many folks prefer the Emu coils because they are a bit more firm. I'm starting to outgrow the Emu coils because of the added weight of the ARB, Slee sliders and skids, etc. Whenever I replace the rear bumper or add a winch I'll move up to a heavier coil.
bugsnbikes,
I actually think that route seems more suitable for me at this time. I'll probably go that route and that will free up some money in the future for some maintenance things I want to do on the cruiser. So will going that route still have a pretty comfortable ride then? Right now it drives like a tank, I swear I hate potholes right now.
Thanks for your advice.
