shock question
Battle Ground WA
I just got a set of ome j springs from a friend and now need shocks. i talked to the guy at four wheel parts and, he said he could order the procomp es 9000 to match the lifted springs. was wondering if theses will work.
i just ordered them, for the second time from summit (they didnt feel like sending them the first time 3 weeks ago for some reason)
anyway, they have a sale 3 for 4 this month, if you want to order them get the 9000's call procomp for the right part # as summit dont know. If you want to know how these work, wait a month and ill do a write up when they show up.
From what I have read on MUD and from my personal experience:
1) Go with OME L Shocks, thats the general consensus
2) If you can afford Bilsteins, they are another good option
3) Doetsch Tech 8000's (what I am running) are also good shocks, and affordable.
But to answer your ?, yes the pro comp 9000 will work with the right adapters. I would not run them on my truck, but that's just me. Just go check out the specs on the OME L shocks, extended/compressed lengths, valving etc. Then try and see how close you can get to the specs on the L shocks. Since these shocks are made for J springs, I'd assume they are properly matched. Good Luck!
I'd get the OME shocks which were designed as a matched set with the springs you have. People badly underestimate the importance of shocks designed WITH the springs, often choosing shocks that simply are the right length. There is so much to shock design I could go on for pages, but especially for rollover safety if this vehicle is driven on public roads. Why are you not considering the OME shocks for these springs? Just curious.
DougM
Thanks for the imput i really appreciate it i was wondering because the ome's are somewhat expensive to say ranchos or procomps.
DougM
I agree with you on matching shocks to your intended use and vehicle but to throw "rollover safety" into the mix is being a little bit of drama queen isn't it? Educate not scare is much better advice.
