Shock Mount Bolt part numbers
For future searchers, the part numbers for the shock mount bolts on the 200 series (or at least on my 2013 Land Cruiser) are:
90105-16088Front Lower Strut Bolt
90178-A0084Front Lower Strut Nut
90119-A0018Rear Lower Shock Bolt
I couldn't find the rear lower bolt anywhere online or even in the parts diagrams, so putting it here for future 'mudders who do a search.
Don't believe there is one for the rears, and the bolt referenced above comes w/ the washer.
:doh: you are correct. i have the TT shock guards sitting in a box waiting to install, might as well replace my bashed up bolt/washer while i'm at it
When i search for that rear bolt it only shows as listed for Sequoia only, which does use a nut. Every site i found it on said not for Land Cruiser
I'll verify once it arrives. That is the part number that I got from Tanner at Olathe Toyota Parts. He said it is correct for my vehicle. The only way I will be able to say for sure is to wait for it to arrive and see if it matches the one currently in there.
If this thread is wrong, I will update the original post to make sure I am not spreading disinformation.
My 2013 doesn't have a nut there, the bolt threads into a threaded post. Not sure about the Sequoia, I've never worked on one.
Here is an image from a 4Runner forum:
Supposedly a M12x1.25 thread, in case you want to clean up the threads with a tap while you're in there.
