Shock leaking?
Omaha, NE, USA
Never dealt with worn shocks before so bear with me. These came on the rig when I got her, Fox 2.0 shocks. Never seen this color leak before so just trying to get a .2 on it. The underside is pretty much rust free and this is more like a paste. So I’m under the assumption that the shock is leaking and possibly clumping up with the gravel roads I travel on. The same color has recently appeared on the knuckle as well? Both passenger side. Thanks in advance.
Looks like shock leak. Check brake line near shock to be sure as well.
Knuckles need some Molly grease (square bolt on top of knuckle). Fox shocks are rebuildable if I remember correctly.
Yes, last I checked Fox will rebuild them for $50/each.
