x2 on the pin to eye conversion. I have 2 sets of JKS shock conversions on mine,
I took the factory rear shocks and mounted them up front with the converter on the bottom, effectively adding an inch or so to their length and saving you the price of a pair.
The other set of converters went at the top mounts of the rear shocks, allowing me to run the very common eye to eye shocks out back. Once you do this you have your choice as to the shock you want in the rear, 5100's, rancho's, skyjacker hydros, etc, etc. You can spend as little or as much as you want.
I personally like a soft shock on my truck which is probably about 95% pavement pounder, although this seems to be the opposite of what everyone else seems to run.
The skyjacker hydros seem to allow the springs to do some of the work and give it a bit of a cadillac ride, which I prefer.
The truck seems to just float over all the bumpy stuff but it probably doesn't corner like a stiff gas shock does, but thats the trade off I guess.
It works for me.
So this option cost me about $70 for the converters and
another $60 for the hydro's = $130 total.
Here's the converters below: 9602's
JKS Manufacturing: Shock Mounting Components
