Shock Change This Weekend
Bend, Oregon
I am changing out my OEM shocks with new OEM shocks (courtesy of cdan) this weekend and will snap photos if anyone is interested in the procedure.
Slee's site has a pretty nice walkthrough, but just wanted to know if anyone wanted pictures of any particular section of the remove/replace.
Just ignore this post if this is a one :banana:, "like the back of my hand" type job. I just feel responsible to give back any info I gather since I have been mooching off all of you for about 2 years now :o.
Best regards & wish me luck,
Riley
Good Luck, and start applyin the PB Blaster every night before bedtime.
Way ahead of you! Started about a week ago when IdahoDoug told me to do so. I may even be able to turn out the nuts/bolts by hand (not too likely)!
:cheers: Riley
Riley
Pics are ALWAYS good! The more documentation the better I always say. Even if it helps just one person it would be worth it right :D
Finished installing the new OEM shocks. Started at 9:30 AM and finished at 2:00 PM on Saturday.
Started on the rear shocks. Everything went as expected. Only problem was trying the torque the upper shock nut to 51 ft.lbs. I only have ratchet/socket style torque wrenches and could not hold the shock shaft solid enough to get the wrench to click. I am sure that I am in the 45 to 50 ft.lb. range and the rubber bushings/cushions are nicely bulged.
The front shocks were a different story...
First, had trouble with the top nuts, even after PB blasting for about 2 weeks prior. The shock just kept turning and I started rounding off the little slotted top of the shaft.
Finally got the driver's side top nut off by wedging a large crescent wrench against the fender well to hold the slotted top of the shock stem and pushing the nut with a box end 17mm wrench. Moved to the lower nut. Ended up twisting off the little slotted end of the lower shock stem. Sat there staring at it for about 20 minutes then realized I only needed to salvage the retainers/washers. Decided to just cut the nut off with the dremel (cleaned most of the PB Blaster off and kept my fire extinguisher handy). The cutting action heated the nut enough to break the nut loose. Passenger side went the same way (only no staring at it for 20 minutes). I did have a rubber strap style pipe/oil filter wrench and after cleaning the lower part of the front shocks I could hold onto the shock shaft and get the nut turning. Used the strap wrench to torque the nuts back on (no click, but pretty sure I am in the 40 to 50 ft.lb. range).
Lessons learned:
PB Blaster is your friend
The only things that are salvaged/reused are: retainers/washers, rear shock top plates & 14mm bolts and rear shock lower bolts.
Harbor Freight shopping list: chain style pipe wrench, propane torch, spanner/open end torque wrench with nice array of metric heads.
The rear shocks were not too bad, but both front shock were completely gone! The old passenger side front shock took about 15 minutes, just sitting on the ground, to stretch back out after compressing to remove!
I snapped a few pictures, but nothing that would really add to what I have found here and what is in the FSM.
Didn't notice a huge difference when driving. A little less body sway in the round-abouts/traffic circles and the front end feels a bit more solid. Any difference I feel is mostly a placebo effect. Just nice knowing that there are new shocks at all 4 corners.
When time for new tires, I will change out the springs with stock height OME and step up to 285s (currently on 265s).
Thanks again for the advice and info. The FSM covers this procedure pretty well.
Riley
I guess I should have just asked a question instead of typing up a novel.
Is there any concern about not getting the full 51 ft.lbs. on the shock nuts?
Thanks,
Riley
