I have a 350 mated to a stock LC 4 speed transmission. The swap was done by the PO and everything works pretty well. Recently I have been having trouble shifting into reverse. I get the nice grinding sound. I can shift into all other gears fine, but I do have to push the clutch in all the way to do it. I have adjusted the clutch as far as I am comfortable, but the adjustment bolt is pretty much threaded out. Should I use a longer bolt? It doesn't matter what RPM's I'm at, sometimes it goes in fine, more times than not it grinds. Any suggestions?
Zac
Zac
