Shift Overlock Override
Raleigh
1992 w/ ~ 225 on the clock, it will not shift out of park w/o using the shift overlock/override button. I have checked the 3 associated fuses (CIG, Stop and ECU-IG) as well as lights (directionals, stop, reverse). I can't seem to figure it out and I have searched the board for solutions but can only find the suggestions I have listed... Any ideas?
...just did some additional reading and saw that the Neutral safety switch can become gummed up. Will check when I get home assuming there is one on the '92 model.
The po of my truck simply zip tied the lever down, never needed to hit the brake to shift out of park. Sorry, no pics.
NSS has nothing to do with the shift interlock solenoid. There is a shift lock "ECU" under the center console. There's also a couple of connectors under there. Very simple circuit that can be diagnosed with a multimeter.
Jon, thanks for the info... I will dig into that this weekend...
Jon, another question... With regards to the center console ECU, do you mean where the shifters are or the center console arm rest? I actually have a Tuffy Security Console and don't recall anything under it. I am going to dig into this when it cools down this evening.
Did you get this figured out @jakesiar? I am having the same problem in my 92.
Sorry, missed this back in Aug... Still working on it and having to use the over ride button to shift out of park.
