Sheared lugnut stud
Utah
I was driving home from a buddy's house today, when on the highway, I get a vibration (60+ MPH). I remembered changing out the USPS front tire the other day, which had a spare, for a recently repaired tire, so I didn't give it much thought, thinking there was mud stuck in the rim or was out of balance.
As I exited the truck and walked towards the suspect tire, I noticed that 2 (count 'em TWO) lugnuts were missing, and that one stud had completely sheared off :eek:. The other 4 nuts were fairly loose as I took them off.
My question is, how do I get what's remaining of the stud out, and where do I get a new one...or a new set?
Also (don't shoot me)... How do I get the rotor off, if need be?
You will have to pull that whole unit off such as the hub/rotor. Then take a punch and hammer the lug through:)
That's what I was afraid of...
I'm not afraid of getting my hands dirty though. Tips on how to remove the hub/rotor? I have an FSM, but I can't find a page on how to do that?
i am no 80 guy but look on your picture you will see that there is bolts running around your lugs those need to come off. But first take off the cover covering the hub then i am sure you will find a c-clip, bearing then 2 54 mill nuts that need to come out and in between those should be a locking tab. :Dthe rest is pretty self explanatary.
but get a fsm to cover that so you will know how to tighten up those nuts. you cant over tighten or under tighten
Is that the front or rear?
A local tire shop crossthreaded 3 on the DS rear recently on my 94. They wouldn't/could'nt put new ones in.
I bought 3 new studs, hammered them out, and used an old school racer's trick by putting two nuts on the stud and using a big socket to tighten, pulled them thru and they seated just fine.
Well, except I overtightened one and sheared it off, but I was in a bind on a saturday in BFE and had to roadtrip it Mon morn.
I had to pull the caliper, but it was no big deal because I had a set of rear pads waiting to go in anyway.
Front... 91 only has discs in front. Rears are drums.
That sucks man. I don't know how the hell this happened though? When I switched out my spare for the normal tire, I pre-torqued the nuts with a torque stick, dropped the lift (this was at work), then tightened them down by hand.
No worries, my point is that I didn't have to pull any of the other bolts that were mentioned, it was a pretty easy job. I have no :banana:s
I've heard of this before, but it usually was because people were using the wrong lugs.. Maybe it just wasn't seated right, I dunno.
I usually find that at least one nut needs a twist or two after a couple of days.
no you are right you do not need to remove those bolts. I was thinking you needed to cause i did last time(but that was cause i had my roters turned):oflu getting the better of me.
Yea and they do need a extra turn or 2 in a couple of days.:DBut ha if your in there go ahead and change the bearings/seals:beer:
So I don't need to remove the disc? I found the page in the FSM that shows how, it doesn't look that hard.
No you do not need to. and yea none of its hard. Just dont use cheap studs. My Napa studs have not broke yet.
Ok. I plan to buy new studs and lugnuts from the local stealership.
Shouldn't be too much... :rolleyes:
Ok...... So I decided to take it down to the shop tomorrow morning, cause I work almost right next to it... As I was putting the tire back on, ANOTHER stud sheared off. No heavy torquing, just spun right off.
Time to replace them all.
easy fixed
You have to separate the hub and the disk toreplace the studs.
Check the section of the FSM that deals with replacing brake disks and this should give you enough info to get it done.
If things go well with the dismantle it should only take about 1 hour to get her all fixed up. Assuming you have a 54mm hub nut socket and all the other tools required. Need a big punch and a bfh to get the sheared of studs out. Replace them all.
AND don't forget to check those wheel nuts a couple of hundred miles after having a wheel off. We find that the USDS side wheel is the most prone to coming loose down here in NZ.
Thanks for the advice, much appreciated.
I decided to take it down to the local shop though...I don't have the time to rip into it. They are going to call me with all the details tomorrow.
I will check the wheels after a little while, that could help.... :o
I used Napa as well, no time to get from CDan.
I still need to order black lugs (3) because the chrome Napa ones look kinda gay.:cool:
Try loosing 4 of 6 on your drive home from the Rubicon and having to swap new ones in while it's a 105 deg. with no work bench, vice, or other comforts...if you are going to change one I would change all of them as someone once said and it's a pretty simple install just follow the FSM. PS big shout out STILL to my Nor Cal buddies who helped with the truck and parts that day
