Shaky 80
PNW
Some of you know that I purchased a 1991 FJ80 sometime in late May early June. When I purchased it, I never drove it above 60 mph. Well I should have taken it up to interstate speeds. Once I bought it cash down, I got on the interstate and she began to shake pretty badly around 60mph+. Shaking went away around 80-90pmh on a nice down hill. I just figured it was tires and tie rod ends, with a chance of a bad alignment. I was leaving to go out of state for several weeks, so I figured it was nothing too sever and drove down here to Texas where I now live.
Here's what I've done to try and eliminate the problem with no results.
1. Rotated the tires twice x2
2. Balanced tires x 2 (once before the road trip and a second after it threw the wheel weights off on the passenger front on the way down to Texas)
3.Wheel alignment ( checked out ok, minor adjustment)
4.New Shocks up front (Bilstein)
5. All new Tie Rod Ends (replaced with Factory Toyota)
6. Replaced the wheel bearing in the front axle (factory Toyota)
Still Shaking pretty badly around 60mph+
I've inspected control arm mounts, and the pan hard rod. All bushings and mounts are normal wear and tear, nothing beyond what I had on my previous FJ80. (it didn't shake)
Doing next:
1. Front Brake rotors (current are warped severely from previous owner)
If that doesn't work:
2. New Tires and Wheels
I was hoping to purchase some new 35's (so i'd have an excuse to put on a lift :)), but I dont want to do this until I get rid of the shaking. A lifted truck with a shake is much more scary than a stock height shaker.
Does anyone else have any suggestions? Could tire separation cause this?
Beyond the money that I've invested in getting the front end to stop shaking. The previous owner did very little pm so I've bout new plugs, wires, cap, rotor, hoses, belts, air filter, battery, front axle seals inner and outer. All are OEM Toyota.
I'm getting a little tired of dropping money into it, but I'd rather go back with factory Toyota than some cheap and un-reliable after market parts.
Any help and suggestions will be greatly appreciated.
I'd guess U-joints. Go under the truck and see if you can wiggle the drive shaft with your hand.
oh yea...forgot to mention that I'm doing the steering stabilizer as soon as it shows up in the mail. Not OEM... but I ordered it through Toyota. It'll probably be here tomorrow with a couple heater hoses.
I checked the u-joints, no movement. Greased'em up and no difference. Didn't even require very many pumps on the ole'grease gun.
If you want a check now, pull off the "easy" end of the stabilizer and see if the shock seems to be shot.
Oh, and start reading up on "steering stabilizer removal", or you'll be posting a "RTH needed" thread real soon. :D
Curtis
RTH?
I had another FJ80 that I did the steering stabilizer on before. it was different than this one though. I remembered it having eyes on both ends as compared to this one which resembles a tie-rod end. i figured a pickle fork and a BFH, or a puller of some sort.
RTH?
Real Time Help.
Sounds like you've got it covered though...
Maybe birfs?
Hey,
Come to think of it, does the the flat mark on the birfield joints play in part of balance? If let say the PO worked on birfs and reinstalled the shaft back into axle overlooking the flat spots. Will this cause an off-balance issue?
Just a thought
Bri
Check the run out on the rims it could have a bend in one or two of them, the tires could be a problem if a cord seporated. Usually these you would feel always and wouldn't go away at higher speeds. Check track bars for tightness there bushings could be worn.
Does this rig have indications that it was in an accident?
X2 on tires as problem. I had issues with other cars and tried everything else until only tires remained. Could you find someone to swap tires with for an hour or so? This would tell you if tires a or rims were involved and really easy to do too! Another issue could be heterodyning. Heterodyne is caused by 2 or more wheels out of balance. If the shaking changes intensity as you drive at the same speed it indicates that heterodyning is occurring. Anything that should be balanced in the dirve train can contribute to this. Tires are the main culprit because they are big, heavy and have a large diameter. Good luck!
:beer:
What about the trunion bearings, have you serviced/checked those? Sounds like bad tires or possible trunion bearing issue. Good luck.
Jack
I've heard of this type of shaking being caused by a loose / bad rear trans mount in the early 80's, crawl under and give that a look.
well all of this certainly helps me out alot. I've inspected the trunion bearings, or at least a minor inspection.
Flat spot on the birfs, well I never thought about that. Does anyone else have any insight on this?
The previous owner said it wasn't in an accident while he owned it, but I bought it knowing that it had been. Just from general knowledge from owning several LC's over the years and knowing what to look for in used vehicles. It's been re-painted, and it has an after market radiator in it. One headlight also sits a little dif. than the other. Tells me front end damage of some sort.
Tires are really beginning to sound like a real issue. They are some cheapo's that the original owner put on. Never heard of them before. He told me they were bought new and he ended up parking the truck for a year. They had cupping before the new shocks, and are all wearing very unusal tire patterns.
Tranny mount? I'll check that as soon as I get a chance today.
Thanks for everyones input, trying to take this all one step at a time. :cheers:
My low speed steering wheel shaking was fixed with a 4 tire balance.
My high speed shudder was a bad U joint on the front DS. After that was fixed, on a trail I bent up my rear DS tube and it made a shudder return.
Fixed the rear DS and replaced U joints, problem solved.
I checked the motor mounts and the tranny mount. Tranny mount looked good. motor mounts looked good, no tears in the rubber or separation. But I did notice that they are probably much softer due to age and wear. I'm considering cost on all three. I'll have to message Cdan or talk to Toyota back home in Colorado.
I'm still waiting on the steering stabilizer, it probably wont show up until Monday now.
Found out that the rotors wont be here for another two weeks due to a machining issue.
I'm thinking about just ordering the new tires right now. I can have them here in approx. three or four days from the day I order them.
Thanks everyone. I'll keep everyone posted and probably post some pictures. Hope everyone has a good weekend.:cheers:
