Hi all. I asked this on my alignment post over a week ago but didnt get any responses.
2004 LX with 248K. Hydraulic suspension was professionally swapped for conventional 2 years ago without touching the torsion bars. I finally got around to cranking them to increase the front height because it was 3" lower than the rear. I'm at 1" lower in front now. Vibration appears to be a common result of too much height on the front end from cranking the TBs, but can someone tell me what causes the vibration? I measured my droop to be 4" on each side, which is 100mm and a fair bit beyond the recommended 50-70mm. Do i need to go back to the TBs and crank the front end back down until i am at 70mm droop in order to remove the vibration? Lets say this puts me at a 2" height different between front and rear... Do i just live with it that way? (With the 3" i started with it rode awful and headlights pointed down) Does a 2 degree (should be 3 degree+) camber from my alignment come in to play on any of this?
Thank you!
Thank you!
