Shackle swap oops. What do you think??
The spring is to close to the frame. Should I get longer shackles or grind and weld the frame??
TIA
John
How would moving it forward help? This is a photo of the frame and spring only. The frame is on jack stands and the body, differentials, motor, tranny etc are not installed. I figure the spring will lenghten when the body and motor are installed, pushing the spring backwards. Also the camera was tilted slightly making the spring look forward of the frame hole.
I would grind the frame..
Really, it depends on how tall you want the rig to be.
1. The military wrap is on the wrong end of the spring. It goes on the fixed end.
2. You might need a little longer shackle. If depends on the shape of the spring. If it is nearly flat, like most stock springs, the eye to eye distance will shorten on both compression and droop. From what you can see in the picture, it looks like the spring has a considerable arch and if so you will need longer shackles.
3. Nothing rides rougher than a spring than can't compress.
1) These FJ25 springs are wrapped at both ends
2) they do have some arch to them
3) Yes, if I leave it this way it will defeat the benifits of the swap
Thanks for the replies, I guess we have a excuse to get some cool plated/greasable shackles!
John
well this info woulda helped in your original post :doh:
who knew it was on jackstands with no motor :confused:
I think youre fine with where you mounted the hanger, as long as you get longer shackles. If your spring bottoms out on the frame before the spring is fully extended, you will get axle wrap, and the pinion may end up in your exhaust if you have a v8 wtih a crossover. Atleast thats what happened to me...
-Dustin
