A shackle reversal is intended to improve higher speed on road manners. Not off road performance.
Mark...
"I see" said the blind man.
Mark...
I am taking on the shackle reversal this weekend. Two questions: 1. Which is better using the front shackle mount in back or drill the frame. 2. do I have to reverse the springs.
Mine didn't need one although I kinda wish I had done a C&T because the front U-Joint is a lil...too close to binding for comfort IMO
I would do the shackle reversal thru the frame. Use 4 " shackles. Set pinion at 10 deg. if you are soa , if you are sua then set it wherever it needs to be. Set the caster at 4 to 6 . Have some view the springs , shackles , when you turn wheel back and forth. You can see where it is bad causing the wandering. what tires you got on there ?
