Self-Exciting Alternator Help
Emporia, KS
Website
www.tornadoalleycruisers.org
I've searched and haven't found an answer or alternative.
My one-wire alternator won't kick on. I've considered the option of adding an ignition wire, but there are no other places to hook up an ignition wire - where the "1" & "2" wires would normally be there is only a black, permanently fused plug.
I've kicked the engine up over 2000 to see if that'd jump start it.
Anyone have luck with putting one of these on a 2F? Do I need to get it re-wired for a 2-wire setup?
TIA for any help.
Chris
Bring it into an electrical shop and have them change it over, and give you the diode to put in the signal circut so that it will excite, but not back-feed through your ignition(switched 12V) and keep the truck running...
:beer:
Hello,
I got a PM from Chris, I thought I would post the essence of the solution. The one wire alternator requires about 3000 rpms and a load(lights)on to self excite. I had the alt rewired for a sense wire and problem was solved. Love the new alternator 2 wire setup.
Questions, PM me
eric
Thanks for the help. I've decided to send it back to the store I purchased it at and have it converted to a 2-wire. Heck, I couldn't even find a 6 mm torx socket to take the thing apart - sometimes living in a smaller town...
So, for now I'm back to stock alternator, no york, running the ARB off of the original CO2 setup I've had for the last couple of years.
