Self Alignment?
It can't be that hard... can it? I have looked around but can't find anything detailed for a 97.
HELP PLEASE>
You can also Do castor and camber using special bearings...but typically if you're running stock suspension with an unbent front housing you only need to adjust toe.
All that is needed to adjust toe is a jack, Jack stands, tire iron two sturdy straight metal rulers, a torpedo level (though a digital bevel box is best), a tape measure and some c-clamps or welding vise grips.
Take the front tires off, set it on stands as close to level front to read as possible, clamp the rulers to the bottom of the brake rotor as evenly as possible side to side (use the level of DBB) and then measure the front width ruler to ruler and the rear width, the front should be a slightly shorter distance. Ta da!
