second screw for turn signal?
I assume you mean the front, if it's like a 97 there is only ONE screw at the top. It is held in by some posts lower down that 'click' in - so takes a bit of 'force' to release the fixture after the ONE top screw is removed.
cheers,
george.
What George said.....
Bookmarking.
Need to pull one today; hope it's really that easy.
If it’s never been removed, the bottom snap fit pin/socket can be quite stubborn.
Pull straight forward towards the front of the truck. You can also look up from underneath and see the pin/socket location. Coming in from under the truck you can gently use a flat blade screwdriver to pry the pin forward.
A little grease on the pin when you reassemble makes it much easier the next time.
