- Thread starter
- #41
(deleted due to double post)
OK, in my world "every other vehicle I've owned".....meant you at some point you had a domestic (my bad if you didn't - clearly you didn't have most Audis or any BMW as they generally ditch the batt under the seat or in the trunk).
If you had a ton of Mazdas or VW's, my sincere apologies. Esp if they were VW's.
You formed an opinion based on "every other vehicle I've owned" - but in another post cite the 70, so you wandered some there.
As for me being rude or dismissive, you used the phrase " ..., and those batteries lasted plenty long." --- I'd call that a 'good enough mentality', it worked long enough for you to state "LASTED PLENTY LONG".
I'm sorry, you win, best of luck on future projects.
Before installing my second battery in the OEM right side box.. I thought long and hard about the reason to install it in the standard manner. After the install and now 6k miles later.. all of the objective ideas put forth in this thread definitely hold true. To prove to myself one of the main technical reasons.. heat was truly a factor. With an IR thermometer I measured the difference in heat between the auxiliary battery and all areas the engine compartment. This was done this past Tuesday when it was warm here. The ambient air temp was 88 and I had driven for approximately 45 minutes.
Aux battery = 97 degrees
Air cleaner = 120 degrees
Exhaust side of firewall midway between the engine and fender = 138 degrees
Firewall more towards the exhaust = 148 degrees
Intake side of firewall = 105 degrees
One last thing worth thinking about and then I am bowing out. Should your battery ever explode for whatever reason and it still happens in todays world no matter that components exist today with newer tech.. it could be very ugly and very damaging. The OEM battery box could very well contain some of the damage within its corrosion resistant space.
