Seat extension bracket question
California
Does anyone know of any seat extension bracket for the 200 LC? I’ve got long legs and struggle to “feel” comfortable in the LC. I’m the past, I had Landtank seat extension bracket for my 80 and they were amazing. I’ve searched and searched for something similar on the 200 but can’t seem to find any solution… if any other tall folks have any recommendations, please let me know. Cheers.
Desert does it has seat jackers that improve the seating angle. I can say as a taller guy they’re of benefit and make the driving position better. They don’t give you more support along your femur length, but again make the angle of the seat more tolerable.
I second this product and it made a noticeable positive difference
There’s also mention on a seat lowering bracket on here somewhere that someone is going to try and repot back
Thank you - yes, I saw those and will order them today to give it a try. I was hoping to get another bracket with 2-3” in pure space.
Not sure that’s possible without some reworking of the rear mounts
Hard to explain but I was looking for a little more lift also and experimented with adding washers to the spacer as a test, but as I went higher, the angle of the rear bracket was further away from sitting flush when tightened
You’ll see what i mean when you install the spacers
Hard to explain but I was looking for a little more loft also and experimented with adding washers to the spacer as a test, but as I went higher, the angle of the rear bracket was further away from sitting flush when tightened
Hmm, ok. Thanks for your insight and I’ll take a look when I install the raisers to the front. Even one additional inch would make a big difference. Cheers.
