You wouldn't want to go through Lexus. There's a thread that Jacket posted about a really good, like stock seat covers replacements.Does lexus also sell the seat cover replacement? I have the aniline (not sure about the spelling) seats, planning on keeping my GX until it does (2023 model). Seeing this thread, I'm thinking it may be a good idea to order a set for the front. With my typically seats are the first to go when I keep a car until it dies.
@Jacket - did you notice any change to the (lame) effectiveness of the seat ventilation with the new OEM foam and aftermarket leather cover?Couple more (better) pics in the direct sunlight. It’s a good match on the Ecru.
Over 800 bucks for the old 2010-2017 OEM leather cover for the bottom only, no foam. Hard pass...Does lexus also sell the seat cover replacement? I have the aniline (not sure about the spelling) seats, planning on keeping my GX until it does (2023 model). Seeing this thread, I'm thinking it may be a good idea to order a set for the front. With my typically seats are the first to go when I keep a car until it dies.
...It's a tedious, sh***ty job. Hog rings suck. Your hands will be sore, cut and bruised. ...I probably would have included the tops as well, but mine are in pretty good shape and I'm a bit leary about the side airbag support with aftermarket leather.
My drivers looked just like yours.Mad props to @Jacket for the write up and the pictures. I tackled my torn driver's seat lower this past weekend, and did the seat back as well. I couldn't find any writeups either here or on CL about doing the seat backs, so I thought I'd add my learnings to this thread.
the highlights:
Here's what I was starting with. 2011 with 198K miles.
- As Jacket mentioned, hog rings suck, and my hands were sore at the end of the day.
- Buy new lower seat foam ahead of time. I found many YT videos of people "refreshing" their foam with a steamer. I thought I could save $190 bucks. You can't. Sliding out of a lifted truck destroys the foam on the outer bolster. No steam in the world is gonna replace missing material. The seat back foam was in good structural shape, so I reused that.
- Get a DECENT set of hog ring pliers, and a few sizes of hog rings. Sure, you can do it with the cheapest options, but I found a good kit, and got another set of pliers with a different angle, and they helped in various places. The job sucks enough, don't make it harder...
- Order a few clips from Toyota/Lexus ahead of time
- The seat back board upper clips, 2 per seat, you'll probably break them. 71769-60040
- The lower trim clips at the front outside edge of the seat bottom.
- View attachment 3649354
- I didn't get these ahead of time, and wasn't going to wait to make a separate trip, so I found some GM ones at AutoZone that were "close enough".
- I couldn't get fabric glue to hold to the foam of the seat heating pads, so i used a hot glue gun. Was a little worried that dried hot glue wouldn't be flexible enough, but be sparing, and glue to the seams, not the seating surface, and you'll be okay.
- On the US Auto Seat covers, the fabric that holds the wooden rod (in place of the OEM wire) is too long to accommodate the opening in the seat heater pads, both on the bottom and back. I didn't want to compromise the pad, so I snipped a bit of the fabric out on the middle rod, both seat bottom and back.
- Get a set of small (10"-12") bolt cutters to remove the OE hog rings, and all the ones you'll inevitably goof up on. I wasted more than I care to admit. I see videos of folks mentioning to use needle nose to remove them.
? No way, cut and go...
- Take lots of picture of every angle of everything, ESPECIALLY if doing the project over several days.
- Get a table to put the seat and supplies on, so you're not stooping over (<- for old men only)
- There were only 2 times I needed an extra set of hands, and that was to compress the foam and stretch the leather to get the edge hooks seated on the metal frame, and that was on the bottom cushion.
- Ah... the airbag on the seat back... I'll put that in a separate post below...
So, the internet says any millisecond delay will surely kill you, the guy that works on these day in day out says it's BS... so you choose. I had him do it anyway, and got the pocket sewn in to my new leather. Peace of mind for another 200K miles, or to whomever gets the truck when I sell it. Plan for this in the timing of your job, because you'll have to take both the old and new covers in for a few days.yeah, my foam was done, the back was cracking, and it was only a matter of time that it ripped somewhere else. Between a new seat experience, and fixing my rattling driver's rear fender liner, it feels and sounds (or doesn't sound, as the case may be) like a new ride (if you ignore the dirty interior and cracking passenger's seat leather - a project for the next few weeks.)My drivers looked just like yours.
But I just sewed it up and it came out great! Although I will still be needing new covers sometime in the future.
All sewed up! Just had to use some matching thread and take my time.
Really appreciate the posts since our GX's are starting to get long in tooth.All finished. Impressed enough with the color match and results, especially for the money.
If you go OEM, you're into it over $2,200 for leather and bottom cushion, labor all on you.
I spent $400 for leather, $200 for the cushion, and $200 for the air bag pocket transfer. I'm pretty sure the quote for the transfer was at least double what I could have gotten if I'd shopped the more budget friendly upholstery shops, but this guy does Lexus dealer repairs, too.
Right? I've seen the trickle-down on the 80 series, 100-series, and now the GX. I have to say, though, that at almost 200K miles, the Lexus is WAY "tighter" than either of my 100 series Land Cruisers, and I've beat the snot out of the Lexus for the last 50K miles. It's still serene and quiet on the road, does 100 mph easily on road trips to TX, and is super quiet. Or maybe I'm just getting old and deaf...Really appreciate the posts since our GX's are starting to get long in tooth.
I remember when we first had our 100 series LC's and there wasn't any info on seat covers, until after about 10 years, then the questions, DIY's and where to go starting being posted.
Now I'm seeing the same thing here.
Again, thanks for posting!![]()
FWIW, While I had the seat out, I also tried implementing a fix for the anemic-at-best seat cooler air flow. I shamelessly copied this from a Reddit thread, only I used some outdoor carpet I had laying around, and hot glued velcro to the fan housing and the 3D printed vent deflector I had previously purchased on etsy. The bottom line is the seat cooling fan sucks, and needs to be replaced. I can diagram the passages in the seat, and toyed with the idea of putting some plastic hose in them to keep them from collapsing, but since they're only under your thighs, and not your butt, I don't think that passage restriction is the issue. It's just an airflow problem. Anyway, here the reddit thread:
I was tired and didn't snap of pic of the GX, and since it was a stupid simple idea, and had the carpet, velcro, and hot glue gun sitting out, I did it on my RX as well. Here's a picture of it in the '13 RX, which also has sucky seat coolers. It's just another way to shunt as much air as possible up into the fan.
haha, haven't driven anywhere yet. It's 110 outside!SOOOO???
You showed all the work, but no comment on results.
Did it improve the air flow? Or is it still like blowing air through a coffee stirring straw?
Meh, at best. Pretty sure the root cause of the problem is just a fan that doesn't move enough air. I can feel air if my clothing layer is thin enough, but it's not a compelling flow, by any stretch of the imagination. With the old leather and foam out for detailed inspection, pretty sure they are not the issue.SOOOO???
