Searching for parts for a non US spec LC200 in the US.
My 2010 LC is due for a water pump, radiator, spark plug and timing belt service. I have moved and the country Im in only has diesel LCs and service my car like its an alien from Mars. So im forced to ship parts from the US to where I am.... Unfortunately my 2010 is a non US spec LC. (has the 4.7L engine) I have the vin for it, but so far no dealers can find the correct parts....My VIN is JTMHT06JXA6062361 if anybody has any clue on sourcing these parts.
You might want to check and see if the Tundra 4.7 parts are compatible. I don't know about the radiator but the water pump, spark plugs, and timing belt might work. I am just throwing this out there since the US 2UZ-FE should be the same as the non-US 4.7's but you should confirm with an expert.
What parts do you need? a list would be helpful.
Also my parts system doesn't like that VIN. If you could get the chassis code off the door build date sticker it would help a lot.. it'll be something like UZJ200R-GNxxx.
If you can't get that, what market was the truck originally sold in? Also list trim level, transmission gears, right or left hand drive, etc to help me narrow down the chassis code.
Cheers and thanks for your time
I need the following:
timing belt service and water pump
radiator
spark plugs
TOYOTA Land Cruiser 4.7, 2010
4.7L 288.24PS Euro 4
Modification4.7
Generation of modelIX
Model codeUZJ200
Vehicle ClassOff-road vehicle/Full-size SUV
Car body typewagon
Engine series2UZ-FE
Fuel typepetrol (Otto cycle)
Aspirationnaturally aspiration
Fuel supplying systemmultipoint injection
Engine displacement, ccm4663
Engine line-upV-shaped engine, 8 cylinders
Engine power212kW@5400
Engine torque445Nm@3400
Standard of power and torque determineDIN
Emissions classificationEuro 4
Fuel consumption19.0 / 11.7 / 14.4
Compression ratio10
Additional information32V, DOHC, EFI, VVT-I, (S x D: 94.0mm x 84.0mm)
Look for AISIN TKT-021 kit. Easier to find than sourcing all those bits from a dealership.
Yes much cheaper and looks just like OEM... bought their kit for my 2001 Avalon.... Timing belt, waterpump, tensioner, idlers, and drive belt..... just might want to also replace both cam and crank seals while your there... 9 years old and if parts are this hard to get, I'd do EVERYTHING behind the timing belt while its all apart. my 2 cents.....
You can try www.partsouq.com
Shipping is a little expensive but is fast.
radiator
spark plugs
Modification4.7
Model codeUZJ200
Car body typewagon
Engine series2UZ-FE
Compression ratio10
What market was it built in?
European market. Although it has a 134 liter (34 gallon) fuel tank which makes me think its a middle east version.
Hey Juan..
I see a couple versions, and don't want you to order the wrong stuff. Please provide the chassis code that is on the build sticker in the door jamb. It'll be where the build date, "mfgd by toyota", probably a barcode is. UZJ200L-GNANKV or something along those lines.
This code is the only way to be precise about part numbers when VIN doesn't work.
