Seals and HG question
So I have gone down the path of deciding to replace all the leaky seals on the motor which led me to deciding to replace the headgasket... and then all the things that I should do while those things are accessible. I will be keeping the cruiser for a least another 10 years.
My thought was to pull the lower intake out of the truck and get it media blasted... coated with a bunch of junk...
Upper half and injectors are off and I am ready to get the head off to send out for machining...
I have been trying to search and find the post on pulling the harness out from between the runners and all that is involved in that. Can anyone point me to it? I can't find it with the search.
That's the same project I want to do! (when I have a second ride, a garage, more time...)
I know beno and Shipwreck each started a thread about doing the HG (beno did a few other things while he was in there ;)). I'm not sure if those are the ones you're referring to.
Best way I would recommend (which is not the way I did it) is to disconnect harness at ECU and pull through the firewall and then pull through the lower intake runner.
The way I did it ( :hillbilly: ) was to cut the connecting piece of metal between the intake runners and pull the harness through. That said, I also had an extra lower intake plenum to replace the cut one with. I just like breaking and cutting things. :grinpimp:
Beno is almost right. :flipoff2:
Don't try to snake the harness through the intake. Once the harness is out from the glove box, lay it out as it naturally wants to lay (read: harness may have some brittle wires so bend as little as possible) Snake the intake along the harness till it comes off.
Clear as mud? Holler if you need anything.
Buck
One half dozen of one, one half dozen of the other!!
Do you mean 6 in one hand, half a dozen in the other?
Have I just blown any chance at the Xmas giveaway?
Interesting approach! How many connectors are we talking... I am assuming there are some on the trans... I have already broke about 5 of the suckers... brittle as hell. I didn't even put a lot of pressure on them... they just crumbled... you don't happen to have pics of the harness laid out do you?
I don't have any pictures.
There are two or three connctors behind the glove box. One of them is straight on looking at it and the other, for me, was about at the 2 oclock position. Then take the little rubber boot off in the engine bay and begin pushing the harness from inside the truck. It will hang up a bit but keep trying. It isn't bad at all and will save a bunch of time in the long run.
Has anyone cut the wires running through the runners, extend them, and re-route them? A few minutes with a soldering gun doesn't seam that bad. I haven't really looked at the problem, just an idea from reading this thread.
There's a lot of wires in that harness. Plus, it's quicker to disconnect than to try and solder every wire.
I too pulled the wire harness out from the firewall and it saved me tons of time. I think it took me an hour to take the glove box off and slowly remove the wires out through the firewall. The Toyota FSM missed it big time on this little maneuver. If you already have broken a bunch of the plastic wire connectors, you are at decision time about a new engine wiring harness. CDan was able to get me 2 fuel injector wire clips which broke on removal. He will need the exact small number on the connector itself. I had to use a magnifying glass to get the numbers correct.
Also, Walmart carburetor cleaner took all the black crap out of the intake for me. It did take 3-4 cans, but it works good.
I have done 5 or so head gaskets on these trucks, and i have always disconnected the plugs above the starter, all of the sensors along the head, both knock sensors, and the continous wire that goes to the O2 sensors, and pulled the harness throught the lower intake. There are a couple of other connections, but they are obvious. all of the year models are just a bit different on how many plugs are right above the starter.
If you remove the harness from the firewall, and route it through the intake after it has been removed, you still have to pull all of the injector connectors. If you remove the head you still have to unplug all of the sensors in the head(only 3).
Also trying to remove the lower intake in the vehicle, and having all of the wiring harness around it, is not the easy way of doing things.
Cutting things is obviously not the way to go.
If you are removing the entire engine/drivetrain, then disconnecting at the firewall is the way to go.
I am actually in the middle of an entire drivetrain swap on a 97 at work.
Houston, if you have any detailed questions i will gladly answer them for you during the process, just pm me.
Awesome advice as usual... thanks guys. I replaced some clips when I did the injectors which broke... they literally crumbled in my fingers. Must be the hot Houston summers...
Isn't a new harness super $$$?
Thanks for the offer Skrewball... I will take you up on it.
Feel a lot more comfortable now...
I will take some pix of the process...
Beno,
Did you have to cut the manifold at only one spot? I think that's the case IIRC. Then did there seem a compelling reason to reconnect across the gap for structural reasons? After all, the massive top of the intake bolts to it and I'd think there's plenty of structure there - especially if you replace the huge intake manifold diagonal brace coming up from the engine block. Talk about overkill...
DougM
Beno,
DougM
It was more of an experiment Doug. I had an extra lower manifold so it was more of a "destructive testing" type of situation.
Once I did cut the tab that crossed over from the #4 to #5 runner the entire manifold widened and gapped more than I could control thus making it impossible to reuse. I just couldn't get the upper and lower manifold bolt holes to line up.
I just recycled the cut lower manifold and used a new one.
