Scout box bracing
Mace
rock scientist..
Staff member
s-Moderator
Moderator
Las Vegas
I guess 40" Irocks, rocks, hydro assist and D60's are hard on crap.
My son (2 years old) was sitting in the drivers seat of my 40 and pretending to drive. I looked over and noticed that the scout box was flexing on the frame. Apparently, sleeving the frame and plating on the inside was not enough.
Has anyone done additional bracing on a scout box? It will be nice to pull the setup out to replace the PS pump anyway so it is not a horrible thing.. But I want it to hold up for a while longer this time.
Ideas?
good question since i'm going with the same box.
what about plating the frame a bit more?
post pics of what you have, maybe we can figure out another way.
any chance of fully boxing the frame in that area to keep it from twisting or what-not?
it is fully boxed and plated on the inside ;)
Outside Plate
When I did mine I plated the outside of the frame aprox 8", then a 6" piece on top of that ( welded of course ). My reason though was to space the box away from the rad/support. Got this from Mark W, and Brett. HTH, Al
Is there room to gusset the frame rails it to the front crossmember? When I did my FJ60 box I used a piece of 3/4 plate to space the box off the rad support. With a couple of inches on either side of the box to "distribute the load"
The problem is that the load is torsional.. I do have a good idea now on how to run a gusset towards the front x member, but to do so requires a relocation of my panhard bar. Which I need to do any way..
I'm not sure where your box is located or what else might interfere, but I use a 3/4 inch plate on the outside of the frame. *About* 8-10 inches long and wide enough to reach to the top and bottom of the frame. It is welded all the way around the edges which ties it into the upper and lower faces of the frame, not just the outside frame. This means that the entire frame has to flex, not just the outer face. I also locate them directly opposite tie in for the front crossmember. Pretty hard for anything to flex in this area.
I do not bolt through the frame, but to the plate only.
Currently I am running this setup with 18 inch wide boggers on 12 inch rims with 1.5 inch spacers. No assist yet, so all of the power goes throught the box. It is a tough rig to steer (assist going in this winter). The box and mount has held up fine for three seasons now.
I also ran a similar setup on a '40 with 42x15s and 1.5 inch spacers. I added assist to that after only a couple of season (ram assist takes all the strain off of the box and it's mounting). But while I had it without the ram I had no problems with the box or mount (except for needed more power of course).
I have used this approach on several other rigs, but they are not running as much tire, so...
Mark...
Can't move the box any farther forward, the front Coilover mounting hoop gets in the way. And I am not positive that I can move it out much more than it currently is. It might hit the coilover itself. I am thinking that 1/4 to 5/16" plates on the inside and outside of the frame with sleeves through the frame and support tying them together will do the job. Then a gussett to the front radiator support as well for good measure.
40 x 13.50x 16.5" Irocks on a D60 with a 2" hydro ram (read slow so sometimes you get a littel ansy trying to get the tires moving) and stuffed on rocks is hard on things. When I first got he steering done, I was able to lift the truck up with the tire if I was on my side enough..
Plus, as the suspension cycles in teh front it can actually straighten out the front tires. This is because the panhard bar is not long enough. Don't let anyone tell you that a PH bar that is not parallel and almost the exact same length as your draglink is perfectly fine. It is not unless you have minimal travel. 16" coilovers make my steering wheel go straight sometimes.
I am kinda hard on steering stuff lol
Mark...
mark,
do you tap the 3/4 plate and thread the mounting bolts into that?
Yep.
Mark...
I've never had a problem with lockwashers. But a little locktite can't hurt.
Mark...
Twisted rails
I saw a FJ55 about a year ago tha had a permanently twisted framerail resulting from abuse with a scout box, he was only running 33inch tires, but there's not much bracing along that part of the frame...
I put a FJ60 steering box onto my FJ55 a while back, and being worried about my frame ending up the same way, looked for some info...came across diagrams of a FJ60's frame. It showed cross braces running at about 45 degrees from the front crossmember, to the frame just in front of the stock motor mounts. I plan to do something similar to my 55 when I lift it. I know you've got a 40, and it's not stock anymore, but some sort of cross brace should help keep things more rigid??
X2
I also have a Scout PS box in my garage as a replacement for the Mini PS box.
Some pics would be great!
All I did when I installed my FJ60 box was to plate the back of the frame for about 9-10" and sleeve the bolts...
After a few hard wheeling trips with 37 and 38" tires, there are no signs of anything failing.
It seems like the best solution is a long 1/2-3/4" plate on the outside of the frame.
Hydro assist should relieve stress on the box mounting by at least 1/2...
LOL
Would love to. But the valve would set me back a pretty penny...
:D
The reason for the brace on the standard saginaw conversion is how far away the shaft and therefore the load is from where the bolts attach the box to the frame. This creates a moment (force acting on a lever arm) at the point where the box mounts. The easiest way to reduce this force it to counter it at the source, hence the brace right at the bottom of the shaft. On the scout box you mount around the shaft so you should not see this moment. If you are seeing movement it should be coming from the bolts sliding within the sleeves (if it's not a close fit), the frame twisting, or the bolts not tight enough.
Ken, the forces exerted on the box are generated by the box but resistance is from the tie rod. So with minor variations due to pittman arm design the forces on the bolts between the boxes is similar.
Both boxes basically mount "around" the shaft. The scouts is just longer..
Jack got me thinkin..
Anyone want a ported hydro assist scout box??? :D
I can basically keep what I have and just install a orbital valve.. Then I don;t have to worry about it :D
