Scored a used Norcold MRFT 60 and need some parts
San Antonio TX
As the title says. I picked up a Norcold MRFT60 for $350 on Craigslist.
It rode around in an older couple's RV then sat in their garage as an overflow fridge for holidays. After being plugged into AC and running for less than an hour on setting 3 it's at 32degrees. I take it this is normal?
Now I need a DC cord and set of handles for it. Also is there a slide that fits this one?
Im new at these and havnt had any luck searching for the items.
Thanks for the help.
Temperature sounds about right. I have a thermometer in mine and monitor it when in use. I've found anything over 1 or 2 will start to freeze things. They're probably all a little different.
Parts seem to be getting harder to find. THe MRFT's are getting a little old. Even if you can find parts, they're usually very expensive. For the handles, probably best to just fab a pair up.
I hear Cruiser Outfitters sells the cords. I'm pretty cheap and would probably build my own - it's only two wires.
Slides should be available - the 60 is a pretty common size.
