Sbc With Pto ?????????
You "may" have to be creative on the exhaust on the drivers side to clear the driveshaft for the winch, also it will not work with Saginaw steering
Why won't Scout Saginaw steering work?
Are you planning on running headers? May be some shaft/ header clearance issues. Aren't those Toy P.T.O.'s only rated at 6K?
I was planning on Scout, ended up with FJ60 after an intensive search for a Scout box.
Scout is 3 bolt, FJ60 is 4 bolt.
Stock FJ60 pitman arm works with stock FJ40 relay rod
Local cruiser shop is 5 min away with plenty of used parts, would have had to ship scout box
There are no scout parts in any junkyards around Atlanta.
*Intensive search? The Scout box dwarfs the 60 box. Compare the sector shafts, not the number of bolts holding it to the frame. Didn't go to the Binder Bulletin Board or try venturing outside the city limits? You couldn't order one from any parts houses either? Okay, guess you'll end up with a spindly shaft'd 60 box, good luck........
tried binder bulletin, missed the boat on some good deals, all that were left were pricey ones that made the FJ60 box an economical/time decision. My truck was sitting, with wheeling season already in session. Didn't have time to sit around and wait for a scout box to pop up.
I've been to plenty of junkyards, and I'm well aware there aren't any inside the city limits, where are you finding your junkyard Scouts?
With the core charge buying one from a parts house becomes a $400+ proposition.
If my minitruck P/S could survive runs up lower 2, upper 2 and schoolbus with 38's then I think the spindly shafted 60 box will too.
Sector shaft size is a moot point with hydro assist anyway...
Never seen a Scout box in person- nice to know it is actually larger. Wish there had been one around when I was looking.
