SBC V-8 Pig Radiator Shroud Ideas
OK, I've got the SBC installed in the pig and I have a Summit Aluminum cross-flow radiator in place but I need some shroud ideas. I have a stock 55 shroud that I may be able to fab in there but it would be close. Any of you V-8 Pig owners please chime in with what you are using please.
Thanks
Thanks
Howdy! I'm kinda the odd ball, cause I don't use a shroud at all. I figured I would add one if I needed to, but, not yet. I am running a FlowKooler water pump, and truck pulleys to run the pump a little faster than stock. I had my original 4-core radiator re-cored with a high density unit. Weighs about double what it used to. I moved the outlet from the back of the lower tank to the bottom, so I can fit up to a 21" fan w/o hitting the hoses, but right now I run a 19" 7 blade solid steel fan, but I do not have room for a clutch, my bad. John
