sbc no spark
Billings, MT
my cruiser was running great. I parked it in the garage and didn't touch it for 2 weeks than when I went to start it..... NO SPARK. I erronously assumed it was my ignition system, and replaced it with an MSD system. NO SPARK. I performed the trouble shooting steps on the MSD instructions and the ignition computer and coil are working properly. I replaced the module in the distributer... NO SPARK. Today I am going to replace the distributer. what is most likely to halt spark in my situation, a worn out distributer, distributer cap, plastic rotor thingymajig that spins distributing the spark to the distributer cap? any insight would be great. Thanks
Brian
yea I am pretty sure I am, it is an HEI style distributer with the three wires coming off the base. I tested the power input plug from the MSD ignition to the distributer and was able to get spark when that plug was short circuited, but once that plug is reattached no spark upon cranking the engine. I even cut out the plug and hard wired it to check if the plug was bad... no luck.
Thanks for the responce
Brian
I have finished replacing the distributer, rotor, and cap... still no spark. This is rediculous and expensive
the HEI has that plug that goes from the body of the dist. to the cap and just out from that is a place where you can wire in a (tach) and a (bat) and should be marked exactly like that. take a wire from the bat. part directly to the battery and see if you get spark. you mention the plug but you didn't mention if the (bat) wire is connected which is separate of that plug. is your engine grounded? also if your replaced several things.. see if the dist. isn't set in correctly or the coil may not be grounded in the cap. there should be a ground wire that you screwed into the dist. when installing the coil. (4 bolts)
