SBC Engine Building
Adventure Teq
Liberty Utah
Website
www.instagram.com
So I'm looking at all my options for replacing my bad 1979 (or there abouts) Chevy 350. I basically want to drop in a carbureted one from the same era in order to minimize the hassle, and I'm just not a fan of computerized engines.
I will likely either get a reman/rebuilt one for $1100-$1700 but I'm really leaning more to this other option. I've called around and I could get a "good running" one from a salvage yard for $250-$400. Now what I'm thinking is that if I just get one of these that are still running and not damaged inside then go ahead and rebuild that one over the next little while I'll be ahead considering that it "shouldn't" need any major parts replacement or serious machine work. I'm thinking it would basically be just a tear down/cleanup/inspection and replacement of seals, gaskets, and use the same sized bearings and piston rings that came out of it as long as they are within spec. With some possible cylinder honing and maybe a valve grind.
So what do you think, does that sound reasonable and sound like it would last another 100000 miles? Or would I probably need to get it fully machined at the same time i.e. bored over, crank ground, rods ground, heads resurfaced, valve guides/seats replaced, ...oh... and new pistons and the whole nine yards? Because if the latter is the case then I'll just save the hassle and drop in a crate/locally rebuilt one and be back on the road within a week or so.
Just to clarify, my engine appears to have been rebuilt a number of times with numerous different engine parts to about the limit of it's rebuilding specs, so I'm done with this one and not even considering rebuilding it.
Thanks guys. :beer:
I think I would pull your engine apart and see what you got. If rebuildable, then rebuild it.
I don't trust "remanufactured" engines. I've pulled some apart to find .030 under bearings and .060 bore sizes etc. One even had seven .040 holes and one .060 hole. Most are past the specs I would want.
Northern auto Parts has rebuild kits with pistons, cam, lifters, oil pump, timing set and everything you need for $200. All name brand parts.
Maybe go local route and buy one running, go hear it run. Then pull it apart and rering, bearings, oilpump, seals, etc. and bolt her up> That is what I am going to do with a 283, bought it running for $250 and will just replace the wear parts unless I see something :confused: .
GL
Pete
I think the chances are high of running into problems with the junkyard bought 350 and you might end up having to spend the money on machining so keep some money aside so just in case you run into that problem your not left on the side of the road..
another thing to consider is downtime.... i'd also lean towards the one that has less downtime (unless yours is currently not working at all) you could rebuild the junkyard engine yourself while still driving around the 40 as is.
good luck though man
the local rebuilt one will probably have a core charge of about $300 on top of the engine cost. Since yours is cashed out it probably won't work as a core either. I say get the engine from the junkyard and look it over. it might just need a bearing, gasket, re-ring job and its good to go. or at least good enough for the girls i go out with. worst case scenario you can use it as the core if you have to go the route of buying a crate engine. i wouldnt just drop it in though...
with my luck it wouldnt last 10 miles.
:cheers:
Thanks fellas keep em coming,
Thanks FL Cruiser, sounds too good to be true: Northern Auto Parts master rebuild kit $169
Sounds like a sweet deal, looking at more similar kits now.
Thanks Bandy, this one's shot right now with a broken piston, that along with the .040 rod bearings I replaced a couple months back due to a rod knock. It's halfway apart already.
Dig around the net. Somebody has a 350 that's built and ready to rock, and he only want 500 for it (his wife is bitching at him because they are about to have their third kid yadda yadda).
i have a rebulit 350 with probably less than a hundred miles. i would like to sell, it came in a old car we purchased, p.o. claimed to put rebuilt engine in and parked it until we bought it. i was curious about the specs so i pulled the head of and measured bore and stroke. everything measured to 350, and a mechanic freind said the cylinders look good, took some pictures also. i started it up a few times and drove it around the block and it ran good. it is a mild stock setup with an edelbrock and a holley on it. has alternantor, hei, brackests, power steering, wires, cast iron manifolds
$500 and my dad will deliver it to you in killeen when he goes to see relatives in waco
contact my dad at sim69z28@aol.com to work out delivery if you want it (my dad may be interested in one of your 40 bumpers at a later time also)
jared
You can find whole cars with good running sbc in them for 300 - 600 all day long in the paper, craigslist etc. My point is that if you plan to buy a running engine get one that you can see and hear run not just on the word of the seller that it ran great when he pulled it. You could avoid having to rering and rebearing a running engine (in which case you might as well rebuild it completely) with a good inspection. First do a visual running inspection. Leaks in valve covers or even in the main seals are no big deal, you want to make sure it is not burning oil and has good oil pressure even after it is warm. Then pull all the plugs and inspect them . Then do a compression test and then do a leak down test ( a tool worth buying or build your own from the web). The leak down will tell you alot about the condition of the ring seals and valve guides more so than a compression test. If the engine has good numbers I would just regasket and seal it and run it.Maybe new timing chain and waterpump. Like I said anything more involved and you might as well do a complete tear down and rebuild it yourself. I have acquired alot of good reliable powerplants this way and it is the only way I would run a used engine.
jared
:doh: It doesn't get any easier than that! Good luck...Now all I have to do is find that deal up in New Hampshire!:cheers:
If you want 100000 miles you should go on and have a fully rebuilt engine. That's a lot of miles for any engine the way these trucks get used, A full rebuild is the only way it's going to have a fighting chance at that. You seem like a guy who knows people. I have a buddy that does my machine work for little or nothing, and full rebuild kits with over sized pistons new oil pumps ect for a 350 are cheaper than for most anyother engine. Check out a summit or a Jegs catalog.
Or the one the guy above is offering looks like a good deal. Delivered is nice too, and no core charge.
100,000 miles is just broken in for a 2F...
THe $500 motor seems to be a pretty good deal. You can't pay for the machine work for your motor for $500.
That said, if you pull your block and have the machine work done, you know what was done, and you can specify what gets done, and how it gets done.
When I built my 2F, I had pretty much every trick in the book done to the motor for $1900 from the Machine Shop. Figure in that the rebuild kit was ~$900 and that's $1000 for the machine work, and I know what was put into the motor, and I know what was done to the motor to insure that it will last a good long while.
Just my 2 cents.
:beer:
Something else to think about is a GM "performance parts" engine. Pops is picking one up for his impala for about $1500 with a warrenty.
Alright fellas, thanks for all the feedback. Here's where it stands.
The pistons are already .040 over but from what I can see so far (won't have on engine stand disassembled til this weekend) the cylinders seem to be in good shape. The crank is also .040 under so it's at it's max already. If the cylinders all check out then I will likely get the rebuild kit with the same sized pistons and rings (.040) and then buy a new standard crank.
Keeping my fingers crossed at this point. If this plan works out it'll end up costing me about $500-$600, and I will have had hands on all the internals so I'll know what exactly to expect and only have myself to kick if it s***s the bed again. And it should be back in by the following weekend (maybe mid week :D ). I'll post up some pics and progress reports as I get going on her.
Keep the suggestions coming, they are greatly appreciated. :beer:
Jeremy, I am truly envious of how much time you have to throw at this project compared to most. You will obviously learn a bunch from the work you do to spec and assemble everything if you go that route.
The $500 delivered engine sounds like a good deal to me.
I also like tfdcruiser's idea of buying a car to pull and engine from. I have got a couple of engines from a local guy who does that in his backyard, and they have ALL turned out ok. THe most expensive one was a 454 with 30k original that cost me $800. THe 350s usually ran in the 250-300 range.
Sounds like an ideal time to look into building a 383, and gaining some additional low end torque, since the crank needs replacing anyway. Just a thought. Al
If you are willing to spend up to the 1700, I would go and get a new Crate motor from GM. You can get a nice NEW motor with a warrenty for less then the 1700. The only way to go! Too many problems with rebiulds..
Shawn
