- Thread starter
- #21
Made some progress today. Put in new spark plugs, installed new wires and started putting the air cleaner back in. I want a second battery under the hood but until I can figure out how to do it I am just going to put the stock on back and hook it back up for now.
I installed the extra pulley wheel and started to put on the belts but the AC belt was too long so I need a new/different belt before I can finish those..
I also started to put the steering linkage back together but it was WAY tow out when put together. By changing from non PS idler and pitman arm to PS ones which are longer somehow managed to make the tie rod ends too long. I cranked them to shorten them to the max but I think they are still too long so back to the parts store to get tie rod ends and adjuster bars for a PS truck to see if they are shorter.
I also switched out the steering column today! Sweet!. I took out the whole column, removed the ignition key plug from my truck and installed it in the tilt column. Then I installed the tilt column which has the intermittent wipers. Tilt works and all blinkers and wiper functions worked. It was plug and play. I will have to use the new SR5 steering wheel that came with the tilt column because the intermittent switch and horn are slightly different and it will just be easier to use the SR5 wheel than modify it any further.
So if anyone needs to do a similar swap it may be easiest to just switch out the whole column like I did.
When I was under the hood working on the plug wires I noticed this broken wire. Does anyone know what this vacuum unit?/switch? that the broken goes to wire does. Vacume switch? on the top of the engine right in the middle, just after the oil filler cap. You can see it in picture 2 also but I show the broken wire in picture 3.
I did it to save time but that back fired, so I am going to remove it. The over load spring does arch up just a bit and once the weight of the truck is on the springs it is almost in contact with it so it is going to stiffen up my ride quite a bit. Any little bump and that spring will come into play. By removing it I will drop it about 1/2" and get it a little closer to level.
t! I jacked up the truck as much as my floor jack would go and hung a string off of the corners of the fenders.
