My rig has OME AND HIGH STEER. STill working on the bumpstops and the pitman arm but it works fine.
Notch and plate your frame for clearance.
A low lift SAS is all about bumpstops. There is a build over on yotatech called the "great white shark build" or something similar, and the guy is running about 2-2.5" of lift with high steer. I spoke to the guy who did the work and after talking with him I am planning on using the FROR hanger kit ( seems to be the lowest at only 1" lift I think) and a set of 84-85 OME front springs which should net me about the same 2.5" which will sit nicely with a set of 33's. High steer will clear as long as I set the bumps up right. It will limit up travel to only a few inches, but honestly that is probably more than I have now with my IFS, and the droop will be much better.
If you want low you will definitely want to stay away from TG leaves, even their 3" packs have some crazy arch.
