sand blasting/frame prep-options
right gear
Hi Wayne- What do you recommend for the right gear and breathing apparatus?
heavy clothes, heavy Coveralls, a full face shield, and a 3m Respirator OK?
thanks
Aaron
Radd Cruisers said:
Your gonna be a day or two with the piss pot cheapie sandblast, been thier.
Budget is a main concern with giving out options for frame restoration, you can do it yourself and get good to moderate finish.
Nothing will creep into the voids like dipping, only other way is to pull the frame apart and blast it, see it done and nothing works better.
I hate sandblasting, did enough with a cheapie hood, you need the real gear and breathing device.
Rob
definetly the best option is to send it out to be blasted, I am just saying that one can do a "decent" job on their own. I cleaned my frame while it was still attached to the main tub and it came out great. Not perfect but great. And all I used was an angle griner wire wheel, some wire brushes and a lot of elbow grease. As long as you clean it up enough to give the paint something to adhere to and use a paint with good adhesion you will be fine. Just wanted to give another perspective on doing this yourself. I have also found that TSP (tri sodium phosphate) is a great cleaner and pretreater to paint. It is cheap and can be found at any home depot.
Noah
If you are going to hot dip galvanize, check out the company first, go look at the stuff they galvanize, when the parts come out of the hot dip they are hot enough to be a bit soft, we had some pretty large steel parts bent when we had to switch galvanizers because of a time crunch. it's pretty much guaranteed that your frame will come back a little warped. that being said, they don't want paint in their acid solution so if your frame is super dirty and has paint on it, they will send it out to be sandblasted and charge you for it, so it would probably be cheaper to blast it first. galvanizing is a extremely cheap and durable coating, last time I checked it cost $0.44 a pound to galvanize things, if you scratch it good though your only option is to cold zinc it with a spray on or brush on product, ends up looking kind of patchy. you will also get a lot of rust bleed in areas like where there are blind holes and rivets, the zinc doesn't flow into cracks well.
