So as luck would have it I found a complete Saginaw conversion in a wrecking yard 40 today. The parts I removed consist of the following:
Collapseable steering shaft with a Spicer joint
Spud shaft with a Spicer joint
Saginaw power steering gear box
Dropped pitman arm
Shortened steering arm
(total cost was around $40)
I am missing and need to know on the following:
Steering pump, can I use the steering pump on the 87 350 with this older Saginaw box? I think the answer is yes, however I figuer I should ask the experts.
Steering lines, what type of truck is the best donar? I suppose that overall lenght of the lines is crucial due to the location of the gear box being so low. I would rather remove some other lines then have some made. I have access to tons of GM parts here in Denver.
I am just going to cut the scab plates from stock metal, and drill the frame corss member with a hole saw as the tech links show. I was not planning on doing power steerin, but this was too good to pass up. I just don't want to cut my rig up too much during the install.
Dropped pitman arm
