Safety of wheel spacers
high desert, ca
Put different wheels and tires on the pig recently and ran into a caliper clearance problem. To solve this I put 0.25" spacers on. How safe is this? Can a small increase in leverage like this shear the studs? The lugs get about 9 1/2 turns on the studs. There is about 1 turn of threads which is not used. Is this a problem? It is pretty inexpensive to get recessed lug nuts if needed. Opinions? I don't feel like loosing a front wheel in traffic or while dropping off a ledge.
Just from reading others' experiences here, you should re-torque them early and check them occasionally, especially if they're aluminum.
Barely drove the thing and the lugs loosened up a little. Retorqueing is quite important with new rims and Al spacers. The previous owner of my vehicle made sure he/she removed all of the wheel weights with the tie rod ends. Grind it till it fits I guess. I have mini-truck arms and 2.5" BS, so no more of that. Now only if I could actually go wheeling in it without slicing the side lugs of my tires. Fix that one soon.
I've been running .25" Alum. spacers for 9 yrs and no problems. I was worried about the same things you are at first. Now the only time I think about them is when I take off a front tire, or see a thread like this one. I did put longer studs on though. Got them at NAPA.
