rust spots on white
Nay, I'm curious about touching up my hatch as well. What kind/brand of "rubbing compound" did you use?
I use 3M Perfect-it II rubbung compound 3m Perfect-it II Foam polishing pad Glaze. You will want to use a good variable speed buffing machine and the 3M white foam pads, hook and loop, and the grey foam pad for finishing, and don't let them get mixed together. What I mean is after you make a pass with the rubbing compound, use a 50/50 water and rubbing alcohol solution in a spray bottle and clean the residue from the surface before moving to the finishing Galzen and grey pad. You can also use a spray bottle with plain water to mist the pad and the paint surface to make it work smoother and longer. Just go to a local paint jobber store and you can purchase everything there and they usually can offer good advise as well, or you can look at http://www.autobodytoolmart.com.
Be sure to mask off the rubber and plastic (like the snorkle) and window trim with good blue or green 1" tape so you don't get rubbing compound and polish on them because you will not be able to get rid of the white residue left behind. You can machine up close to those areas and do the difficultt spots by hand but not in circular motion but rather use a linear back and fourth pattern when working by hand to prevent leaving swirls in the paint. you can then use a good sealer and then put on a couple of thin coats of Carnuba. If you take care of your paint like this and keep a good layer of carnuba wax on the surface, it will act as a protective shell and the usual scratches you get from driving off road usually will not make it through to your clear coat and paint. They say the more carnuba wax you apply, the better and more lustrious the paint surface will be but it does wear off within a couple of weeks so you will want to reapply as needed or until it does not bead in the rain. They also make a sprayable carnuba wax which can be used while drying after each wash.
