Well, the lubricant spray that came with your Mother's Clay kit is basically a detailing spray that can be used by itself to remove light surface contamanets. If you can find a local automotive paint supplier, they will have the clay bars which you can get in different coarseness, light, medium and hard, and the lubricant spray which is also a detail spray product with some cleaning additives. I have all three and start out with the light bar first, and then I move to medium or hard depending on its ability to romove the contaminates. When you can just pass the bar ofer an area with no pressure and it does not try to stick or you don't hear it passing over the trash, that area should be clean. If something has etched itself into the paint, any part of it that is higher that the paint film will be removed by the bar but the bar will not remove any paint so you could still see the trash level with or beneath the surface. What I do when that happens is take a small piece of good quality 2000 grit wet/dry paper and soak it in water for about 20 min to soften the paper backing and use a painters detailing flat sanding tool or even sometimes my finger and while adding water, lightly sand the spot until the trash dissapears. Then you need to smooth out those 200 grit scratches with a rubbing compound just on that area and then follow with a polish.
Also keep in mind that after you have clayed your paint, there is no protection, wax or anything on the surface... Just pure paint. You will want to seal the paint wit a good sealer and then go on with a good quality carnuba wax. I use a sealer by Wolfghang and Pinnacle Sovreign Carnuba wax. If you need to use the clay on a trouble area, then be sure to follow up with the sealer and Carnuba afterwards. Autogeek.net has some very useful information on this and you can purchase through them what products you decide on. Yes they cost more than the over the counter products but these are professional products which have not been compromised with buffers and additives. The Pinnacle Soverign Carnuba is pure carnuba from the tree and it smells almost good enough to eat and because it is pure, it goes on and off much easier than some of the others. I just apply by hand rather than my orbital. Just read and follow the manufacteurs instructions and you will achieve beautiful results.
