Rust repair rear quarters
Pensacola, Fl.
I removed my rear bumper and found this. :eek: The rig is originally from Michigan . Does anybody make repair panels for this area of the quarters?
Thats cool Toyota stamped their name in the fender
no point in repairing those..............get out some tape---and tape a horizontal line right under the "toyota"-->>then get out a sawzall and remove the entire lower portion.
search "hi clearance rear bumper". Nay has a detailed thread of his tail tuck and he didnt even weld it shut.
Nothing important in that area......pull your rear cargo panel---look down and remove the sunroof drain hose.....then chop away.
You could angle your cut like the "red" one----or flat like the "yellow".....both these will retain that fender bolt if you want to keep your fenders on.
then while you are at it-----cut your rear exhaust back to the black area after it clears the frame.
