Runs Cold
Folsom, CA
I've had the truck about 2 months. I'm thinking thermostat, but, here is the situation I'd like to get feedback on: The LC gets to running temp on the gauge; when I am driving around town, there is heat coming out the heater; when I am at a stop, cool air - not heated. Went to the Sierras, as the temp outside dropped, the temp gauge dropped and the heat from the heater dropped. I flushed the cooling system, that was a brown/red mess, it seemed to help a bit, but still cool air out the heater when stopped. Any thoughts or experience with this would be great!
Possibly a plugged heater core, but replacing that thermostate with OEM unit will certainly not hurt.
Thanks for the input so far. I was wondering about the heater core, but couldn't think of why I would get heat while driving and none while stopped.
I'd say almost guaranteed to be a busted t-stat.
Easy to replace, but don't forget the o-ring that sits on top of it, and install it carefully so it's sitting where it's supposed to.
Curtis
rbryan
I missed the part about of getting heat while you drove. Read through it to fast. Start with thermostat and go from there.
If it was a heater core issue, you can test that out, by turning on the rear heat and seeing how that reacts. If the temp is the same, then it shouldn't be a heater core issue, since both heater cores source their coolent indepedently. In other words, one blocked heater core, shouldn't affect the other.
Themostat seems like the obviously choice here. In cold weather, if the thermostat was open, it should take a really long time to warm up also.
Have you checked the coolant level? If you low in coolant, there will be no enough heat deliver to the heater while you are idling, and probably just enough while you are moving... That's said, it is good idea to replace the thermostat assuming you don't know how long it has been there. (I still have the original stock there, and plan to replace it for my next coolant drain.)
Has the thermostat been tested in accordance with the FSM? That would be my first step. I had a similar condition with a FJ80; the thermostat was faulty and the heater worked much better after it was R&R'd.
I had the same thing going on with my '91 3FE.
I phoned American Toyota (1-800-432-6668), spoke with cruiserdan and ordered the parts for the job:
SO42 Thermostat, Part #90916-03052
SO10 Gasket, WA, Part #16341-61030
SO41 Gasket, Part Part #90430-43002
Not sure which of the gaskets is the o-ring, but cdan can set you right.
Knowledgeable and friendly customer service from cdan and American Toyota. Good prices, too.
Upon removal of thermostat housing I found the old thermostat was literally in pieces - but no damage, that I could tell.
After replacement - WOW, what a difference. Engine runs way smooth and quieter. Amazing what a difference this made for the related sensors.
Only thing I'm not sure about: after engine is warmed up, the temp gauge reads slightly over half-way up. And it's not even summer yet. Radiator is fairly new, recently flushed and coolant fresh and clean.
I will have to monitor this and see what happens when the weather starts to get really warm.
I saved the destructed thermostat for a pic, but I just havent' gotten around to taking the pic yet.
Thanks for the feedback. I'll be replacing over the weekend. voorland80, I hoping for the same results.
Good luck with the fix. Let us know how it turns out.
