Running without front axle innerd's?
South Australia
Hey guy's, I've got a 93' that's had a few issues in the front axle the time I've owned it, and now i need to drive it as the pig's defected the s*** out of my ute.
First up I snapped two bolt's that tie the steering arm to the swivel hub which caused the shaft to chew through everything and had to do a full kit on the passenger's side (New Stud axle, bushing, seal's, shaft and CV, that was about 5000km ago. it got parked up for a good 5 year's until I recently started driving it again;
Wen't out camping and pushed a suitable firewood tree a bit too far and wedged the root into the tie rod,
had to drive the beast home luckily full dirt (apart from crossing the road) funnest 15km trip ever.
It sat like this until I moved, promptly acquired a new tie rod and just drove it to the new house.
after a year I've decided to get the girl going as a daily again. started cruising and noticed the hub violently spewing diff oil, confirmed the violentness after finding it empty just 50km after topping it up, and now the diff should probably be checked, worrying amount of metal shaving's.
So I've ripped my hub apart and found the inner shaft has major wear on the seal point, enough to catch the groove with a finger nail, and the stud bushing's bearings were free rolling between the shaft and the stud, would it purely have been caused by the 15k trip of sever toe out or might this be a combo deal from the past problem and my axle housing is bent?
I've got the full bearing/seal kit but now I've discovered i'll need a new shaft I'm not to keen on getting one, throwing it all back in for no real reason just to wear another one.
closest shop is 300km away, and I don't feel like paying a lucrative amount to ship the axle housing to get checked (it would be cheaper to drive there)
So to my ultimate question, am I all good to just leave the axle/CV's out, slap in new wheel bearings, remove the front prop shaft and leave the center diff locked until i can get it checked over. No diff spinning, no oil, no leak!? I only plan on putting around town with it (and of course to the closest shop) until it's ultimately fixed.
google speedy sleeve.
repair the seal surface on the shaft with a sleeve and put it all back together. sounds like you'll need to put all your new bearings and seals etc in the hubs anyway.
To leave shafts out, you'll eventually have to pull it all apart again and re-do almost all the same work. using a speedy sleeve is quick, cheap, and will save you a lot of work. and could be mailed to you
otherwise, answer is yes, you can drive it indefinitely in rear wheel drive only
I drove the new seal in a bit farther than the original had been in so I could use a new spot on the axle that didn't have a groove. No leaks yet and there's quite a bit of range that you can drive the seal into. If you take the innards out, seems fine too, no axle shafts/cv and no driveshaft, locked center, you've got a 2WD truck. You'll probably want to cover the hole where the axle shaft would engage the splines so you don't get dirt in there. Seems like an axle housing bent enough to cause failure would be fairly obvious, but I've never seen one.
