running rough or vibration
Squamish
hey guys my truck seems to have a wierd vibration as soon as i put it in drive and start driving......i dont know much about mechanics...just wondering what your think it may be .....my guess is the universal joints on the drive shaft are needing replacing......any ideas?
ive got a 97 fzj80 collectors edition with 285 75 16 cooper stt's and the ome medium lift other than that shes bone stock
thought as much. It's possible you have a wiring harness problem where the main harness passes over the EGR assembly. It usually manifests itself in drive but not in Reverse.
A good first test is to apply the brakes in drive and see if the rough running appears and then while in reverse. If when in reverse the engine runs smooth you would want to look closely at that harness.
Be sure to also check for cracks in the air tube that goes from the MAF sensor over to the throttle body.
ok thanks im actually jsut going out to pick up some diner now so ill give those things a try and get back to you ok ...thanks
yeah i think it seems fine in reverse....but what does a bunch of wires have to do with my truck vibrating
