Running rich and lean!?
Milwaukee, WI
Website
www.poppfitness.com
CEL comes on randomly since I put in new plugs, belts, idler pulleys, and new fluids all around. Pulled the codes and got both 25 and 26 which are running rich and running too lean. Has anybody ever had this? What could it be? Thanks
-Zach
How old are your O2 sensors? I usually get a 26 with bad O2 sensors.
Also check and make sure the tube running from the air filter to TB is sealing properly (not cracked, clamps tight). This has also given me a CEL (26 I think).
You might also check the plug wires for damage.
I think the O2 sensors are original, so at 190K it makes sense that they might be the problem. The Intake tube seems tight and not cracked, but I will give it a better look tomorrow.
I think my O2's are original as well.
:hhmm:
Only one code in the past year and a half I've had it.
:meh:
I'm at the same mileage as you and have replaced them once, at around 150K. I never threw a code, but I *did* see noticable improvements in power and mileage after the change. There's a huge O2 sensor thread around here somewhere: Many folks report significant performance gains, some don't.
I really to where I should change them again, but I'm lazy...;p
Curtis
when you get codes for both rich and lean, it's almost always a vacuum leak somewhere. There are a lot of rubber hoses under the hood that can crack over time causing the leak. The reason it throws both codes is because the engine is sucking in air from somewhere other than the air filter, so the computer thinks it's running lean, so it squirts more gas in, then it's running rich. I've had both of these codes come up on several of my Toyota trucks in the past and almost everytime I was able to find a small vacuum leak somewhere that was the culprit.
Makes a lot of sense, I will give it a good look. Thanks for the input.
I figured it out. When My dad checked the transmission fluid level he unplugged one of the vacuum lines that were kind of in the way. I ran it for about 20 miles but noticed they were unplugged when I got back and put them back in. The funny part is that the CEL didn't come on until about 200 miles later. I am guessing the ECU remembered the code but didn't triggered the CEL for a while. I cleared the codes ran it for a while and rechecked the codes and it looks good now, so everyone can sleep soundly tonight.
