Running Lean
1995.5 fzj w/obdII 135,000mi recently changed both o2 sensors, no cracks in intake, no cel.
Changed my plugs today and the tips looked a little whitish/grey which i believe means it is running lean. I also get some lean gurgling on decel if my foot is all the way off the gas.
Mileage is ok 13-14mpg.
Is it lean? Is this a problem? Does it need to be richer? How can we make it richer if need be.
Peyton
A picture of the plugs would probablly help more than the description. The 1FZ-FE has dual knock sensors so detonation on these engines is not very common. Also, the ECU monitors several parameters and adjusts the fuel mixture accordingly.
How long have the new O2 sensors been in use?
Did you use OEM sensors?
Have you used any fuel additives lately?
Did your CEL come on telling you its running lean? I had this happen also about 4 months ago. Took it to a buddy's shop and he showed me that the air flow sensor gets built up with CRUD over the years and needs to be cleaned.. Since its so dirty and can't monitor/measure how much air is actually being pulled in so it leans out thinking its not getting much air.
Mine was so bad I had to take a small screwdriver and practically scratch it off.. I felt like dentist does when scraping plaque off your teeth!!! DOH!...:D
Good luck..
Scott
Check the fuel trim values to see if the ECU is trying to adjust the mixture. It would read in the + range if it is enrichening it and in the - range if it is trying to lean it out. Zero is the ideal range. These engines run lean by design, so it is not clear that it is too lean. If it is, maybe the O2 sensor is reading out of range and sending the computer bad info.
