Ok, here is the history and where I am now. Truck is a 1996, 182,000 miles. At 150,000 miles, May 2006, I replaced the radiator, fan clutch (Blue hub) and did a full coolant flush with Toyota Red (was in there before also). The cooling system worked great, truck did not go over 210f even in 108f weather with the A/C going full bore when going up a hill.
Fast forward to August 2008. I'm going up to Tahoe, it is 106f out. The truck starts to run hot. I have to keep out of the gas the entire way up or it goes over 215f. The fan clutch does not seem to be engaging, I figure time for new fluid. I swap the fluid to the 6k fluid and forget about it.
Nov 2008, tow my buddies boat, 4500 pounds, temps in the 60s. I have trouble with it heating up on the freeway and going over a 1000 foot climb, it goes all the way to 220f, no fan noise.
I changed the coolant the end of November, then changed the thermostat last week.
I went up to Tahoe this weekend, temps in the low 40s on the flat, down to the 20s on the way up the mountain. The truck is running about 195f the entire way on the flats (slightly above halfway), goes up if I push it above 70mph and going up to 210f on the climbs with me taking it easy. The temp climbs slowly and goes down slowly. On long downhills it stabilizes at about 180f. The fan never engages.
It is getting progressively worse, I am also getting tremendous heat soak around town, I park, run into a store, come out and the gauge is at 215f then cools slowly.
I was originally thinking head gasket, but I have no coolant loss, I have done the bubble test running the engine at 3000+ rpm when hot, and I get no bubbles in the overflow tank. The fan makes a great startup roar with the new fluid in it.
I am thinking the radiator is plugged even though it is only 2.5 years old. It seem to make sense, as if the head gasket was bad, then entire radiator would heat up from the combustion gasses, and trigger the fan clutch. That isn't happening here. Also, in 20f weather, the truck at 50+ mph should have more than enough airflow that the fan clutch doesn't matter.
What say the fellow mudders?
